It's coming along nicely. I wish I still had a heated Garage. Just did a bunch of stuff on my dd last weekend at 40 degrees. Can't wait to see it all under the truck and hooked up. Good thought on buying two rolls of Wire At the same time. I try to Do The same if I got a lot Of welding to Do. Although mine is nothing like what you got goin on it always sucks to have a job half done and run out of material.
Yeah, I peeked at the wire roll about a week ago too.... just to make sure I wasn't going to be surprised. But you know those "marketing types".....they build the roll with a large center spindle so that it APPEARS that you have a really massive amount of wire on the spool..... in reality there is very little left.
I'm going through a lot of shielding gas too. Mostly because I run at stupid-high CFMs...but I guess it makes sense that if your burning tons of wire, you are using tons of gas also. While I've still got my "loaner car" I should throw the dirty old tanks in the trunk and swap them out for 2 new ones!!! :D
-G
That is us. We are the company on Pirate. And here, though with a smaller presence.
not sure if its the same brand but that is definitely what i was referring too.. i plan on picking one up as well.
We are the only company making a universal reduction kit for drill presses.
The result was only OK. I'm using the 2-1/2" annular saw which is a pretty big load on my low-end drillpress. They really aren't designed to cut through 1/4" plate either. I tried WD-40 as a cutting fluid, then moved up to my tap oil...and eventually settled on regular old motor oil to try to keep the heat down and keep the cutter from binding and locking up once it got about 1/2 way into the plate.
Very nice work on that center mount section. Clean and very rigid looking. Just as an FYI- we keep long belts in stock to allow you to run two of our reduction kits at once, one off each side of the drill press. With single and double kits, this allows for a reduction of 2:1, 4:1, 8:1, or 16:1. your minimum RPM could be as low as 37.5 RPM (that's lower than a 2J head Bridgeport Milling Machine).
... long belts in stock to allow you to run two of our reduction kits at once, one off each side of the drill press. With single and double kits, this allows for a reduction of 2:1, 4:1, 8:1, or 16:1. your minimum RPM could be as low as 37.5 RPM (that's lower than a 2J head Bridgeport Milling Machine).
ZOMG, it's not just like a Doubler kit for your press, it's like an Atlas! :bow:
-- A
Greg probably has a hernia from trying to throw that massive monolith around!
Something like that... :D
If I'm being honest, my motivation dropped to basically zero ever since the daylight savings time change. It really affects me when it's already dark as I get home from work.... And combined with the cold weather it's as if my body just wants to hibernate instead of raging on projects in the garage.
So basically, the monolith was re-installed under the truck (it still needs to have the final speed holes drilled and a touch more finish welding) and the front links were reattached. That's when I realized that my mock-up front links aren't going to be strong enough to support the weight of the truck... So there want much point in rushing to get things back together for an outdoor photo. I need to take some careful measurements and order up a complete set of Branik aluminum links..... But with my current lack of motivation, I didn't even bother.
I took off a bunch of extra days for Thanksgiving, bit I'm spending it building wainscoting in the dining room. I usually hate working on the house projects but for some reason, this project isn't bothering me too much. I've got probably two more days of that, then maybe 1 day of serious "garage cleanup" work to get my workspace looking good again. Hopefully that will give me the kick in the pants I need to get back to this project. :dunno:
-G
-G
I feel the same way. It is very hard to leave a 68 degree house and go outside and work in the cold and darkness. I really need to get a heater for the shop. :doah:
Here's a photo of the wainscoting project in case anyone cares...
-G
And now I know why I've been missing my Saturday and Sunday morning texts of "Project of the Day" from ya... :dunno:
The wood work looks very nice, :waytogo: but not as nice as the missing pic of your rig outside. :tongue1:
Hurry up and get back on your horse. I need to see if the secret wheel project is going to work so I know what way to go. :thumb:
-G
So true. I really find myself disliking the time change this year.
I know exactly how you feel Greg! I need to get into my garage and get it organized, but I can't seem to find the energy. But, the house project is turning out very nice and it should be a good change of pace. We will all still be here when you make it back to the Blazer, it's one of the few builds I still follow religiously.
2013.12.11 - UPDATE! - I'M GOING ROGUE......
As you all know, it's been a rough few weeks and I haven't been making any efforts to get out into the garage to work on the truck project. A lack of motivation.... probably weather-related, time change....whatever. I just didn't care about it at all.
Fortunately, Joe over at RogueFab saw my previous thread posts and contacted me about my drillpress issues, and we talked for a while about his reduction kits and how they would be a low-cost way to give me better cutting capabilities, and finish up all of those 2" speedholes in the monolith crossmember. He suggested a 4:1 reduction kit based on my particular drillpress (Delta, Model 17-965) and a few days ago the kit arrived via UPS...... it gave me some motivation to get back into the shop and start spinning a few wrenches.
Here's the kit that I received: (Diet Coke not included) :D
It consists of a large offset pulley mounting plate, and a set of 4:1 ratio pulleys that will cut the speed of the motor down to a fraction of it's previous setting (about 25% of original, I'd say! :D )
Here is the original speed chart for my Delta. This is a woodworking drillpress, so the spindle speeds are substantially higher than what you really want for metalworking.... as we all know, REAL metalworking drillpresses are a LOT more money than the woodworking ones (I think I paid maybe $300 for this one brand new).
The idea of being able to drop these speeds in a cost-effective way was very tempting. Here's an example of how the setup will actually affect my spindle speeds using the slowest pulley combinations:
215 RPM -> 54 RPM
310 RPM -> 78 RPM
435 RPM -> 109 RPM
580 RPM -> 145 RPM
Nice.....
Step 1 is pulling the motor from the drillpress, though to be honest I probably could have installed the new plate without unwiring it completely. Live and learn.
The next step is to install the pillowblock bearings and shaft onto the offset pulley plate....
This gives you a place to drop on the large 8" speed reduction pulley.... there is a small 2" new pulley that gets installed on the motor itself, and the pulley stack that used to live on the motor, is transferred on top of that large 8" pulley wheel. (In this shot the pulley stack is not installed yet)
You can also see that the sheetmetal pulley tray is interfering with the installation of the rear pulley and belt. This is not unexpected... you'll see the fix later on.
The only real tricky part is figuring out which way to install the large motor plate (pillowblocks facing forward vs. facing rearward) as this will affect the belt lengths and tension that you can apply to the forward belt that turns the drill spindle. I tried it both ways, and ended up with the pillowblocks facing forward as shown. The front belt has a little more slack than the rear belts but so far it seems like it's going to be OK.
Another thing I learned is that it's MUCH easier to install this kit if you lay the drillpress down on it's face so that you can work on the motor/plate installation horizontally. Trying to hold the all of those heavy parts up with one arm, while installing nuts and bolts with the other hand is nearly impossible.... you've been warned! :haha:
The final shot:
As you will notice, the kit doesn't really take up too much extra space and tucks-in pretty nicely. You DO have to make some cuts in the original sheetmetal pan and top cover of your drillpress so that you'll have adequate belt clearances.... a minor tradeoff, IMHO considering what you end up with as an end result.
Speaking of which..... the kit really WORKS! I set the pulleys to the slowest speed (54 RPM) and turned on the press and it's amazing how slowly the 2" holesaw is spinning now. :waytogo: I can easily count the revolutions as they spin by, and there's a chance that it might even be a bit TOO slow at it's slowest setting. A nice problem to have.....
The other benefit that I haven't tested yet is the increase in useable torque. The frustration I was having at my old setting of 215 RPM was not only the excessive speed, but the fact that the cutter would drag and eventually stall-out halfway through the cut. With all of this additional gear reduction, I've got a LOT more torque available and I expect that my issues with stalling are over as well.
Overall, the kit looks really good... I am actually looking forward to getting back out into the garage again to cut some holes now, so perhaps that is the best feature of all.....!!
-G
