2009.09.09 - UPDATE! - A VIEW OF DE-SPARE...
As mentioned earlier, I got sidetracked a little bit over the weekend with some "tweaking" of the existing cagework to get all the dimensions to within my personal tolerance limit of 1/8"...some areas were creeping further away and it was time to cut a few spot welds, remove a few bars and make the adjustments now while it was still fairly simple.
Once I was back on track, it was time to cut off the "pinwheel tubes" coming off the back of the cage, and set them up correctly near the b-pillar area with some .120" wall DOM sleeves (12" long per side). This gave me a chance to play with a new set of holesaws from SnapOn...
These babies are cool! They are like minature hole saw bits (very sharp) with a spring loaded centering pin. All you do is centerpunch the hole you want to drill and go directly to the size you want (in this case 3/8") without going through the normal progression of smaller bits to larger ones to get a clean hole. I used this bit to cut a few rosette holes on each side of the sleeve to anchor it in place permanently.... then I cranked up the welder and puddled up the holes..
I put a bevel on each side of the outer tube also, so that when I go to do that butt-weld of the two tubes, I'll have a good deep, and strong weld there also. Basically, the cage is 1/4" thick through that section now, so strength is not going to be an issue.
Once that was done, it was time to put the rear bars in for the last fitment and lock them down also...
As you can see, I also bent another spreader like the first two for a consistent look across the top of the cage. Those 15-degree bends at each end are a subtle design touch, and give the cage just a bit more headroom over the seats too.
Another shot from a slightly different angle with the tailgate down to show the repeated shape of those upper cage spreader bars and the landing spots for the rearmost c-pillar bars....
Here's the "attic view" of the cage, in an attempt to show the rear seat legroom (HA!) with the seat in it's stock location. Actually, the legroom isn't terrible and would probably be fine for almost anyone that needed to ride back there for anything other than a long highway trip.
Here's where I got stymied today....and the reason for today's tagline pun:
I need to come up with a way to carry a spare for long trips and for wheeling too. This shot is with the 39" tire loaded tight against the tailgate and laid-back against the rear seat. Basically it blocks the entire view out the rearview mirror.... it's bad.
The original hope was that the angle would be enough to drop it down further out of sight, but unless I carve out about an 8" deep trough in the rear floor, there's no way to get the tire down low enough to clear my rearward vision. The only other option is to lay the tire flat in the bed, but even then I'd have to push the seat forward another 3" or more to get the tailgate to close....and the legroom back there is already pretty limited.
More head scratching to do... but overall the weekend's progress was very satisfying to say the least.
