That new panel looks beautiful! It's cool to see this area going back together since this is an area that a lot of us 1st gen guys have rust issues in, but most of us have never seen the onion peeled back this far to really understand how all the pieces fit together.
How much of the cross seal are you going to have to cut out for drive shaft fitment? Is the drive shaft brake far enough forward that it will sit in front of the cross seal without interference?
Driveshaft?
AWWW CRAP!!!!!!
j/k
The driveline brake sits in front of the step panel (even with my more aggressive engine/trans/atlas setback position). The CV part of the shaft is the part that passes through the panel. For obvious strength reasons I want to be VERY precise with the amount of material that I remove to provide clearance for the rear driveshaft. The material will get pretty thin above that cutout, so I don't want to create a weak point that will buckle if I ever let a "fat kid" climb into the back seat area.
It might be a good area to incorporate a driveshaft loop (which I wanted to do anyway)... that way I can close-off the underside of that driveshaft cutout and add a lot of strength back into the area.
-G
