It won't be anything store-bought....
I have been watching AJs troubles getting his engine crossmember to work, I'm not sure that one is designed to work with BBCs
Anyway, with no more "C" channel on the frame to hang crossmembers in, everythings is going to end up custom-made. I might end up doing a mounting "ear" on the crossmembers so that they will rest on the top edge of the framerails to help support the weight. That way I'm not counting on the through-bolts shear strength to hold the motor and driveline.
I'm probably about a week away from dealing with crossmember designs, you'll have to stay tuned in.
Who knows, the Doug Thorleys Burt has (you have a set too, right??) may have cleared better, but I want / need 2" primaries. There's just so many variables to work with here...
