2014.11.16 - UPDATE! - THE LONGEST FISHMOUTH...!!!
More weekend progress toward establishing a strong upper strut mount for the rear struts.... :waytogo:
Step 1: Establish a support for a double-shear connection.
I figured that adding a second parallel tube would probably be a nice way to get to the "other" side of the strut to support it, and since it wouldn't end up any wider than the wheeltub, it really wasn't costing me any space for the back seat either. I put a bend on the rear part of it so that it wouldn't encroach unnecessarily on the bed space. I clamped 3 lengths of angle iron to the existing bedrail tubes so that I could just lay the new tube on there and didn't have to fight it from twisting and falling out of position all the time. I also helped to insure that the end result would be dead-on perfect in it's alignment with everything else. :D
As you may have noticed, even though I used BendTech software to plan the bend, it didn't exactly work out right. I had to play a bunch of games a both ends (with extra filler tube) to extend the tube, and to increase the spacing between it and the original bedrail tube. Getting that rear fishmouth to fit perfectly took a LOT of time and fiddling. In typical fashion, the first bar took HOURS to complete... so I made up a paper wrapper for the fishmouth and was able to transfer it to the final part, and also was able to turn it "inside out" and use the mirror image template for the drivers side too.
Total time to complete the driver's side tube was less than 30 minutes from start to finish....!
The rear tapers on the inside tubes had a very important extra feature: They allowed a bit of extra room for the seatback to fit. The rear seat is about 50" wide, and I'm only at about 48.5" between the wheeltubs currently....so the seat didn't actually fit as far forward as I wanted in this photo. Utimately, the seat will have to be stripped down completely so that I can cut about 2 - 3" from the center of the frame, weld it all back together...then have it reupholstered. Once it's done, I doubt anyone would even notice it's been messed-with.
So... that took care of getting a nice upper mount. Which allowed me to move on to
Step 2: Support the strut so it doesn't flex and bend those horizontal bedrail tubes! :doah:
In a bit of serendipity, I discovered that by following the angled profile of the factory wheeltub (which is exactly 45* by the way) and putting just a slight gap between the tub and the tubing.... I could land a support tube into the corner of the rock slider structure underneath the truck and also end up in a perfect spot directly underneath the upper strut area. :bow:
A simple 45* fishmouth on one end and a 45* flat cut on the other was all it took to knock it out. Both sides were completed in about an hour. My luck was so good that it scared me.... so I decided to stop there (at about 11:30PM last night) and just take a few more photos before cleaning up and getting some sleep.
Here's a great shot giving a sense of how the rear passenger will see things.
I really like the double parallel-tube layout. It's just BEGGING for a top plate in the armrest area with a few holes cut for some cupholders! LOL. The trapezoidal area underneath and in the forward areas makes a great spot for a subwoofer enclosure and looks to have about 2.5 cu ft. of space, which should be PLENTY for almost any speaker I decide to use there.
Here's a pure side-profile of the end-of-the-night progress.
It looks like I could add another diagonal bar on the trailing edge of those wheeltubs pretty easily and tie them into the C-pillar support. (That would be Step 3) I'm hopeful that will be enough structure to support the weight of the truck and the upper strut mount. If not, I'll either have to go above the bedrail and do some additional tie-ins to the top of the cage or go down into the factory framerails.... which means I will lose my 48" wide bed floor and future dreams of hauling plywood and drywall... :doah:
-G
-G[/QUOTE]
Looking awesome. I like the armrest idea!! Haha plywood:haha:
It was funny looking back in your build back in double digits...you had hopes of blazer bash 2010!! Your might as well attitude got ya again!!! You still have a couple years left.
Be careful......
Back then I was replacing sheetmetal in my A-pillar area (just like YOU are now)..... things have a way of going out-of-control once you learn that it's only metal and EVERYTHING can be manipulated and improved.
Look back at your own thread in about 5 years, I think you'll be surprised at where you ended up! :whistle: :waytogo:
-G
Greg, I'm digging the double bar arm rest! That's going to look really clean when you finish it up! Well done as always sir [emoji144]
Seems like it will be a pinch point for the passengers arms. That strut isn't going to move around much at the top, but it will move.
Martin
Martin
Yeah....I'm going to make sure there is plating on the inside of those mounts so that curious fingers (or arms) can't get in there!!! :yikes:
-G
id hate to be the ribs of the guys in the back..... looks tight if it got bummpy
Be careful......
-G
I hope I get infected with this bug as u did. I always remind myself to slow down while I'm progressing step back and think. After all after we finally finish these then what would we do!? We will have to start all over again! :D
I doubt there would ever be two guys back there on a "real" offroad outing.... probably just Charlie in a car seat sitting dead-center. :waytogo:
Last night, I did sit back there just to get the "vibe" of what it would be like for a back seat passenger. It's pretty nice. Keep in mind the seat is going to come forward another few inches from what you see in these photos, so the top of the strut will be almost aligned with the backrest of the seat. That should help minimize banged-up elbows, etc.
Those inside rails actually are pretty good "grab handles" for a single, full-sized person back there... just sit in the middle, strap in tightly and stretch your arms to either side to hold on!!!! :D
-G
Looks nice Greg. Are you putting the back seat armrests back on or leaving them off in favor of the tube?
Also, my wheel tubs are pretty close to having 48.5" of space between them. I can just squeeze a 4.8 sheet of plywood between them. Are you sure you moved the tubs that far? Maybe I need to go measure mine again to be sure.
By the time you get finished it might be Charlie sitting on the side next to a little sister in a car seat. :eek1:
Seriously though, do whatever you can to maintain as much width in the seat as you can. Charlie won't be small forever. My seat is full width still and taking more than one kid is getting tight already with the oldest one only 12 and a girl. A couple of teenage boys need room!
Are you adding any bars between the b and c pillars in between. That is a commonly unsupported area and that's a long run of tube on that rear down bar. I know it might take away from the pleasingly current very clean aesthetics but that is a long unsupported span of tube
Brian,
I'll have to got check my notes, but I'm pretty sure the stock spacing between the wheeltubs is 51".... I'm at about 48.5" now (best estimate) which is just about maxed-out. The factory seat is a touch wider at the front, and gets narrower in the seatbelt area. No matter what, I'm going to have to cut it down (or buy a custom-fit) suspension bench seat that matches visually....
Eric,
You mean above the bedrail area? :dunno: I'm trying REALLY hard to walk the line between aesthetics and "tube farm"...... A cage can always be made safer by adding "just one more" triangulated tube, but I'm starting to get anxiety about building what ends up looking like a "race cage" inside of a classically-restomodded 1st Gen. That's just not the look I want to end up with.....
I like that most of the structural underpinnings that were added this weekend are completely below that bedrail sightline, so even though things got a lot stronger the outward appearance of the truck is still quite simple and unassuming. I'm certainly expecting to do a bunch of corner gussets for the tubes that have already been installed... just hoping that I can stop there and the rear struts don't force me to clutter the upper cage areas with large diagonal tubes. :doah:
-G
He Greg, I like the new taper and how it will center itself as you tighten the bolts. It should reduce the fitting and stuff necessary for the 5 slide in tubes. One thing to note, the step does make it so the taper won't get really right, however, the step may also prevent the taper from requiring a hydraulic puller to remove it. So you have to decide where the compromise is there. Are the 5 large bolts enough to hold it in place after the taper centers it for you? Likely. I don't know if you want to remove the step and then the taper may get so tight that you can't get it off without damaging it or requiring special tools.
Also, make sure the hole in the center is large enough to get the bolt started with the taper offset all the way to one side or the other.
I know exactly what ya mean. It's not the strut mount I am concerned with though. When I build cages it is always for worst case scenarios. Now sometimes space money time or aesthetics really doesn't allow me to do what I want. I am much more concerned about the long unsupported span of tube above the bed rail. What I would call a rear down bar.
I am not even quite sure how I would do it. Seeing that the best thing to do would be to put the support in the dead middle of the span but that would make it off the strut mount and would look awful. I would put it almost where the orange ratchet strap comes down. Intersecting with the new down tube to the slider support. Adding that tube could also help simplify the roof. You could do a /|\ instead of a huge X
Just a suggestion though. Lots of cages I have built if I had my druthers I would have added one or two more tubes. But the final say is the customer and like you they wanted it to look clean.
Eric,
Thanks for the input, I always appreciate your opinion. :bow:
Just to illustrate how neurotic I am, this is what my brain imagines when you mentioned adding "just one more down tube" to the cage.
:haha::haha::haha:
It's a slippery slope..... and I feel like I'm balanced right at the edge of it.
-G
:haha::haha:
Oh trust me I know exactly how ya feel. I don't mind the look of tube farms just not on my own crap. Hortons cage was built with exactly what I thought I could get away with and not an inch more of tube. And in all reality if I would have just changed a couple tubes it might not have bent as much or more importantly where it did
I don't think that it's very funny using a pic of my rig and just painting the tubes red to use as your example. :D :haha:
What are ya planning for a disco on the 45 bar down to the slider?
