2017.05.08 - UPDATE!! - PREPARING TO MERGE...!!!
It's getting closer and closer.....
The objective in the next few days (as weather permits) is to get the truck moved back over to the left side of the garage and position it underneath the bedfloor / rollcage to merge the two parts back together.
That leaves a whole host of small(ish) tasks that need to be completed, so this weekend those got tackled and the results were quite gratifying.
Step 1: Frame Tweaks - There was a mysterious discrepancy in the rear most cross-sill that I could never figure out. For some reason, the cross sill seemed slightly "off" dimensionally, and visually there just seemed to be something not quite 100% square about the way it lined up with the framehorns. It took a while and a bunch of measurements but eventually the issue was discovered.
The fabricated driver's side framerail had a small dimensional error where it was sleeved to the original factory frame. It's not clear whether this was due to the fitment in the sleeve itself, or perhaps some slight "puliing" of all the welded seams on the fabricated framerail, or even just slight error during the cutting and fitment of all those angled box sections. Clearly, even a very small error becomes a rather noticeable one when it is extended 4 feet down the framerail. By the time the frame and cross-sill intersected, the error was 1/2" which explained why the rear cross-sill never seemed to fit well.
The solution was obvious, but unfortunately was a rather big PITA.... A vertical slice was needed in the first bend joint to allow the framerail to be pulled inward by 1/2" where it could then be re-welded to make the rear framerails 100% parallel. The problem was that the vertical joints had all been fishplated with a full-perimeter weld (and a large interior hole for an extra plug-weld), so the repair would require that the entire plate be removed first....
What a pain. Cutoff wheel all the way around the fishplate, roughly 1/4" inside of the original welds allowed the plate to be separated slowly and carefully....leaving behind a massive amount of old weld to be flapwheeled down flush again. Once that was complete, the vertical cut was made and the framerail was gently guided into the new correct position and the seam was welded back up. Now the only thing left is an "I.O.U" for a new fishplate... (fortunately, I have a LARGE plastic bin full of all my original paper templates, so making a new plate won't take much time)
The resulting opening is nice, square and the rear cross-sill finally fits the way it was always supposed to.
Time to move on.
The bedfloor needed some work on the underside, mainly to have all of the permanent convoluted plates stitch-welded to the bedfloor so that they will stay in place when things are unbolted. Unfortunately, when they were first installed, I neglected to clean off the EDP paint and I knew it would contaminate any welding that I tried to do... so systematically each plate was unbolted, then the area around the plate (and slightly underneath each edge) was carefully cleaned to bare metal... then the plates were reattached and welded up. Lather, rinse, repeat, 12 times.
As part of this process the familiar wooden dolly and large green casters were unbolted from the bedfloor to give better access to the various plates... and it served as a good reminder that this assembly isn't going to be rolled around and stored in the corner anymore (it HAS been almost 1 year since it was purchased)
A lot of time is spent comparing the two large pieces of this build lately. During that process last night, I noticed an important interference that wasn't previously an issue. When the new rear frameside upper link mounts were built to provide clearance for the exhaust routing.... the large speedholed top plate encroached in the area where the #3 Body Mount cross-sill would normally land. With the original link mount this area was wide open... but now clearly it was not going to work. So all the the spot welds were marked and centerpunched... then carefully drilled-out to remove the cross-sill.
As it turns out, there is plenty of support for the bedfloor directly next to this location anyway. All four of the B-pillar cage points land on a new cross sill in that same area, so having the factory cross-sill wasn't doing anything useful in that area anymore. With the cross-sill removed, it was time to dress down the sharp edges and give all the exposed metal a quick mist-coat of Ryoken Green to keep everything rust-free.
(In this image, you can see all the paint touchups near the bottom where the crosssill was removed, and the lower 4 plates where the B-pillar tubes are landing)
So..... That just about wraps up the bedfloor prep for now. Tonight the next process steps will be to fab-up that fishplate and at least get it tacked into place.... then add a couple of small vertical supports under the frameplates where the rear strut tubes land. (Those tabs will probably also end up being great locations to add exhaust hangers to support the rear section of the exhaust)... Re-install the fuel tank to confirm that I didn't just screw up the clearances by re-squaring the framerails (fingers crossed!!!)..... and if the rain holds off, maybe get the truck re-assembled and see what it looks like for the first time with a complete rear bedfloor!!
-G
