Re: pics of the new 72 project...updates 8-18-04
Wow guys...
I am about to make a huge dead line...
Running, driving, wheels and tires and new suspension and ready for paint by the end of October...
Lets see if I can at least get close to the dead line /forums/images/graemlins/yikes.gif
Week of September 13-17th plan..
Monday .. pull the 67 around back, remove rear axel, trailing arms, cross member, brackets, track bar.. /forums/images/graemlins/grind.gif go pick up ford nine rear from Rich’s shop.
Tuesday set 72 truck frame on jack stands air lift, cut , section and re-weld frame back up
Wednesday remove leaf springs and all brackets, clean and install trailing arm brackets, coil buckets ect. Disassemble front suspension and steering.
Thursday clean up thick spots on cross members, and start sand blasting and frame prep.
Friday shoot the etching primer, and frame coating
20th-24th
Monday reinstall all painted and prepped brackets on frame, install fuel lines and break lines, and rear lines and rear wiring along rails.
Tuesday install new motor mounts, clean and prep big block for install. Drop turbo 400 off to rebuild shop
Wednesday purchase new calipers, and pads, shock and rear frame bolts hardware ect, new ball joints, tie rods ends , idler arm ect. Start trailing arm bracket mounts.
Thursday install the big pig of a big block, test fit exhaust for routing through cross member, fab mounts.
Friday -..nadda
sep 27th-oct 1st
Install 4/6 drop kit, coils, shocks, track bar, drop spindles, new rotors and break hardware and wheel studs. Bolt up spare trailer rims and tires in front.
Weld on rear mounts and rear coils and shock relocation kit.
Have chassis rolling and done by 1st... /forums/images/graemlins/rolleyes.gif.. /forums/images/graemlins/dunno.gif
oct 4th-8th
Place body in shop on chassis cart... start the door shaving, coat door inner panel with rubberized sound deadener. re-install hardware, install new door guides and felts.
-cap the rear of the cab. Lots of work here.. /forums/images/graemlins/doah.gif
-start rocker added support and stiffening
-finish windshield metal work
This is a big goal..ok it is huge
Wish me luck, I hope if I set weekly goals and time lines then I will have a good chance at finishing this thing.
Other do-dads along the way, Ricks cowl hood, 68-fenders, crager ss wheels, new carpet, dash, and kick panels. Key less door popper kit from chassis tech. Seats from a late model chevy/gmc ECT 60/40 or 40/20/40
This is nutty, and seems unlikly..but I will give her hell /forums/images/graemlins/peace.gif
Still need to find the seats, step side bed and choose tires, not to mention the shaving and filling and metal work involved... /forums/images/graemlins/peace.gif
