Agent_Orange
then just for fun 8)
You just got smoked by a 2 stroke!
Sled looks awesome.
Now we see some rusted out pieces of sh*t here is Wisconsin, but you must have searched high and low to find the biggest rustiest truck in the country to fix up.
quote]
I know right! LMC I should get an award or sponsorship or something. Haha
Thanks
someone wann point me in the right direction here. not a Auto trans guy... for all i know there are tiny little wizards in the case that make the magic happen. might be time to transplant a SM465.Low fluid level? Might be worth putting an extra quart of ATF in there just to confirm.... My Burb would act like it was in neutral when the fluid level got low.
Worth a shot.... Spontaneous failure with no advance warning seems suspicious to me.
-G
I also made sure it was started before i tried to drive it, not just make motor sounds while sitting behind the wheel.well if by spontaneous failure you mean not having moved an inch under it's own power for 6 months when i was rebuilding the front half, yeah i would think it would not be an issue either.
TCase in Nuetral... thank youI also made sure it was started before i tried to drive it, not just make motor sounds while sitting behind the wheel.
