73 K20....crossmember time
He was talking about the plug on top of the SM465. That is for the reverse lights.
The switch on the NP208 is for the 4x4 indicator lamp.
Martin
Yeah when I swapped my th 400 out for a 465....the reverse lights don`t work anymore! :haha:
I haven`t bothered fixing that yet.
I still don't have Mutt's LED ones working yet either... :doah:
hmmmmm, now that's a small project I can sneak in some time...
Martin
there we go
full circle cluster f*** LMAO
I've got a lot of plugs that don't do anything, figured it was just another one whistling Dixie:haha:
Why would it need to be?
Martin
Dunno. I saw a buggy use the pto cover for support a while back. I guess thats overkill haha.
Meh just holler out "watchout you phucks im backing up"!
Hmm I needs led ones too. I want to be able to leave the lights on for a while. leds would be nice and bright for seeing what im backing into too.
there we go
Lol the stooges! thanks guys for clearing up the plug stuff.
As long as I have back up lights the cops wont call in the swat team on me!
Made some more progress today getting some highly unethical parts off this thing. Smog canister went bye bye and so did the egr. I need to either make or find a cheap blockoff plate. Took the stupid cruise control off also.
Cant wait to have this spaghetti mess cleaned up.
lol, my EGR was left in place but when I installed the intake, I used gaskets that don't have EGR cut out lol. Also, I may have welded the holes inside the intake for the EGR "leak". :D
You are still going to want a canister, really. Just find an older one with less nipples. Gas tank inlet, outlet to carb. It's really not a bad idea.
Hahaha I just tried to buy an egr block off plate on summit it and they wont ship it due to it being an illegal in my state. So much for being the land of the free. I hate this state often. Im still amazed we can buy big tires.
Hahaha im going to make one tomorrow since I cant buy a block off plate.
I still have it. I dont want it back in that truck through. Not unless I absolutely need it but itll never be hooked to the carb again.
Summit complains a lot about smog stuff but they still send me stuff. Are you sure it's not just warning you?
The canister can just be vented to air also. Just consider it as a vent for the gas tank that in the case of a tip over, it wont leak.
really though, Summit will send that part. Even if you listed your vehicle as a 75 or older it would still complain
they'll send the parts, just a warning will pop up as mentioned.
Pretty damn easy to make a block off though.
Yeah they have some issue with me. pic attached
No dice. Ill just make one. The only reason i entertained the idea of buying one is because summit has a cheapie for $4.
kerts comp mounts.. or ORD's, same thing.. poly's mang... :D
Energy suspension factory style poly have good reviews.
I decided to go with Kert's competition poly mounts.
Ok good to know! I like kerts mounts...
Ill check out ord too. poly it is!
Side note...I destroyed a poly mount on my crossmember. it had less than 20 miles on it...defective yeah? Theres nothing near it to make it fail...just tore it.
if you where running a poly trans, and rubber motors, that's why... vice versa would have been ok, but never trans without motors..
you're lucky you didn't break the adapter....
