Time to get back out wheeling
I can't imagine that would be an easy task without some sheetmetal experience and proper tooling.
I'm trying to make mine out of a hard plastic that attaches to the frame then to the fender but its a pita to put it in then pull out to cut and repeating thr process over and over
From searching on pirate4x4 I've found a few other people having this issue but am trying to find out a little more. I'm still running the warn premiums for now. I picked some 35 spline ones from supersize75k5Is that a common issue with the shaft? Never heard of that issue.
Did you upgrade to the Yukon hubs?
What spring setup are you running?
I'm running 52" springs front and rear. Your blazer is sick too!
Oh gosh, that's so nice of you.
As for your axle, my buddy had the same issue with his axle shaft. He took some emery cloth to the splines, and the axles slid in another 1.5" and fixed his issue.
You can use the race from a D60 carrier bearing on the inner wheel bearing to move the hub assembly outward approx 1/8".
Edit: 1/8", not 1/4".
Still lookin sick as hell
