Dave,
Here is a link to the pictures of my '87 2wd crewcab. It was planned to be a build thread, but It really only turned out to be a brief overview with pictures. The truck was a 454/th400 but is now a 1st gen VE cummins/NV4500. I used a gm nv4500 and swapped input etc. to make it work with the cummins.
http://67-72chevytrucks.com/vboard/showthread.php?t=461815
also here is a link to a thread that outlines the parts I used for the hydro clutch setup. I used a GM Master and Dodge slave with fittings I pieced together
http://www.4btswaps.com/forum/showthread.php?19010-k30-12valve-swap-motor-mounts
I am in Eaton Rapids, MI. so if you are ever interested you can come and check it out, I have loose ends still but worked the truck fairly hard in this configuration over the summer and am very happy with it. The truck moves effortlessly without a load. It could use a turbocharger upgrade, but otherwise I am happy. Right now the engine is completely stock other than a 3200 gov spring.
The questions I posted previously to Jess about a Dmax swap, just wondering what kind of hurdles there is to overcome there too.
I am so stuck on wanting an auto though. As many problems as I had with the Maiden trans you would think I would shy away, but I'm still heavily leaning towards an auto. Of course OD would be nice too as with the Allison.
Thanks JL, looks like you have made some good progress with yours.
Do you have air and cruise on it? Was wondering about a cruise setup with a Diesel swap too. Whats a diesel use for cruise control?
