93 would be a VE pump, which is great pump for reliabilty and can be turned up to around 400ish HP
I'd be all over that if I had 3k lying about.
So finding an RH would be the best auto for my needs right?yeah, but its not a huge loss you could still expect to see 19-20 Mpg empty with 3.55-3.73 rear end gears and stockish sized tires
What about the heat build up with a non lockup converter towing for long distances though?
This sounds like more than enough power for me, what does it do for economy w/ 12k in tow at 70mph?My motor is a 91 with a ve pump. With $200 and a couple hours of time you can just about double the HP and torque from the factory setting. (Factory ratings are 160 HP/ 400 tq) I installed a fuel pin and governor spring and also buried the full fuel pin in the pump. I can easily light up the 37" duals on pavement if I want to.burnout
With 4.10 and OD Im looking at 2200 rpm with my 31.5 tires at 70mph
Is that too much for decent fuel exonomy? Say 12 or better pulling 18k GCWR??
