understandably so Chris....it will stay!
Chris did you say the factory intercooler will fit in our front ends when turned upside down?
I was wondering what others have done to package the front end stuff behind the grille. such as:
1) Fan...stock Cummins or other?
2) Shroud...depending on fan used I guess?
3) Radiator...GM type or make use of the Dodge unit?
4) Intercooler
5) Oil cooler(s)
6) A/C condensor...I will eventually be using a Vintage Air unit or similar. What have you used?
I'm using a 94-02 Dodge intercooler, it fits nicely around the bigger GM radiator mounted upside down. Some of the core support did have to be trimmed.
I would highly recommend the stock fan, they move a ton of air and it fits, barely.
