Pegs the needle.
High volume pump.
Martin
Nice.... this is mine warm
Pegs the needle.
High volume pump.
Martin
What weight oil is in this?
Yeah, that looks 17 ish at hot idle which isn't horrible.
glad you got the emblem already Dean, that actually took way less time than I expected!
what is your idle rpm? I think we had about 750 when the choke was open, and about 1500 when on high idle?
750rpm on a cold engine would be good to see above #20 w/ 5w30 in it, at 1500rpm cold should be up to 30#.... when fully warmed up, 15# at 750 is fine, but you should be up to 30 or so at 3000rpm when warmed up.
