77 The Black Truck "Ratbag"
Wired up the radio today but only one speaker works. I checked the outputs for the rear on the bench and I was sure they both worked... crap!
I tested the speakers individually today they work.
Tested power from the leads off the radio. Has power on the + side. Should there be power on - as well?
I could use the outputs for the front speakers and give that a try? Unless that would be a bad idea for some reason? I was only going to use two speakers anyway.
