I would use the no-title as bargaining leverage. That should be fairly easy to get around. Either with a bonded title or getting the correct paperwork from the SOS and having the "previous owner" fill it out. Provided it has a clean history, all the SOS is after is their shot at some of the $$$.
But.....if you have clean title of you current tub if your name now (fairly positive you do), are you afraid of swapping the VIN from your tub? I know it's technically frowned upon but I've done several VIN swaps and never run across any issues as long as you aren't trying to title jump.
Think of how the car restoration crowd does it. Say you have an old Yenko Camaro. You wreck it and find a regular 6cylinder car to use the body to fix it with. You reuse your VIN and subframe/parts, only using the tub from the good car. This is a grey area I know, but as far as legality goes....I see no issue with doing it this way.
FWIW: Now when you scrap any vehicle at a scrap yard in Michigan, they only care about title for the frame. You can bring in any/all of the body work (even the cowl with the VIN!) and they have no problem taking it. But they won't touch any part of the frame without a title. Kind of ass backwards if you ask me, but that is how it works now. This all started a few years ago when the state started cracking down on all the scrap theft. So according to the state, title stays with frame, not body.
