Okay so this is pretty much my mistake. Dangit
So the easy solution as I see it is to temporarily weld on a bar just above where it is tied into the body.
Cut the crossbar at the C pillar out.
Get a ratchet strap. Ratchet the top bars where it is too wide in. Making sure your ratchet strap is out of the way to fit the new bar and out of the way to weld it in.
Ratchet together.
You will be amazed at how much this will move it in.
Cut new C pillar crossbar and weld in.
I pretty much forgot Dave was ever going to run a top so I never test fitted it.
Eric, I can't tell you how many times I've looked at that bar even on build Saturday, and never thought about the hardtop going over it
. It's not a big deal as I thought it was, and using your way of making the top of the bars come in, is the way I'll do it. It should work out real good.I will then run a few more bars on top to give head protection, and strengthen up the rear part of the cage.
just spent the last 2 hours catching up on this thread and have only made it to post 550....
