love me my wix / napa gold filters
She looks like my dog when I get home from work.
Yep BROKE!76zimmer submitted a new Build:
77K5. The IronMaiden....Lunched the trans.
Read more about this build here...
Trans? I wonder if my name was used in vain...Yep BROKE!
the manual valve also goes through all positions as it should, so that's fine.
when the transfer cases are in a gear low or high range, and the trans is in park the vehicle will hold, so I believe the transfer cases are OK?
Yes it worked as it did before, drive it around my property a bit loaded up and headed to the dunes.Yeah should be. Did it work at all after you put it in? I assume you drove it on the trailer.
Sounds right.I am guessing broken pump gear or stripped spline in forward drum or input hub. You could put a pressure gauge on the line pressure tap and see if anyone is home in pumpville
Yeah, from the high level we saw in the dunes I suspected no pump (that and no response from trans or engine while towing through gears) but the vehicle wasn't quite level.if fluid level dosnt change when engine is running then pump is not pumping fluid .
