'78 K10 Build
Been to lazy today to drain mine but im guessing its going to look a lot like that :doah:
Dry sand is the worst.
Martin
And what makes ya say that?? My stock a$$ blazer does just fine on it.
And I dont even have hub caps :eek1:
:haha:
I hate dry sand, lugs you down, and is way to easy to get stuck in. The old sand trails out in the Sandhills are way better to drive on after a rain.
Martin
Do it as soon as you can. Drain it into a clean pan, so if it is not contaminated, you can put it back in. Otherwise, if it is contaminated, it is hard on bearings.
Martin
Martin
Its contaminated there is 2 puddles of what reminds me of (gritty hand cleaner) under my front end right now....both inner axle seals were pissing out yesterday :doah:
I'd check your 14 bolt as well, just pull the plug and stick your finger in the hole . . . . .
My 14 bolt has yet to take on water though.
Martin
Hey meow. Dont be hatin on sand. Your supposed to drive in dry sand like us normal people :D
Even in 4wd I could barely move. It seems like its really hard on stuff to drive through the dry stuff. Yeah I know the wet stuff is bad too but it's more fun.
My 14 took on a little water but not as bad as the 44. Going to drain them tomorrow.
Hmm must be. I run 12 up front and 10 in the back and have no trouble, even running in 2wd alot. And mine are mud tires :dunno:
Mine are on their way to being bald so I'm guessing it's the tires. My buddies with Iroks didn't have near as much trouble and they weren't aired down.
