Clutch or assist?
Martin
Already has hydro assist steering
Clutch or assist?
Martin
So what brand steering stabilizer is that? Does it seem to take away some of the bumpsteer? I put an expensive Moog stabilizer on mine a while back, but I still get some bumpsteer.
Okay. The Moog I got looked just like the stock one. It was black. I think it was like $50 or $70 or something like that. The tube is a smaller diameter than the one you have.
No look west Texas power steering pump mods.
)I did the pump mod. In my build thread I took some pics of me doing it too. I even took the pump out of the truck (some people can do it with it still in the truck, but I couldn't get access to the flow piston on the back with in still on the truck) and I think it only took me about 30 min to do, including taking the pump out and putting it back in. I think it's a worthwhile mod to do even if you don't have hydro assist (yet!!)
A smaller pulley will pump more fluid as well. Definitely need dual belts and good wrap. If you're going to change out your balancer and mod your pump anyway why don't you just cut to the chase and throw on that serp system that you have laying around? I believe that you can simply change the pulley on your existing, soon to be modded pump, and it will fit in the serp setup. There are also "off the shelf" smaller serp pullies from other applications that will work when you upgrade your accessory drive. You can't beat the wrap of a serp system.
Why do you need to change balancer? Just change the pulley.
Yeah I probably should just put the serp setup on, but then I think, why do all that when I can just find a TBI engine with it all on there already? I mean jeez, what's the point of being ambiguously gay if I could be obnoxiously gay?
There's like 8 bolts holding a serp setup on, sir gay.
I guess if we wanted to get all technical, isn't there only 4 bolts holding an engine/tranny/TC combo in place?
Sir Gay.. lol
