So ive been battling the drivers side door bit by bit each day. When i took the doors off i drilled alignment holes in the brackets so i could re install after doing bushings and door pins. The passenger side door is damn near rust free and a keeper besides having a little whiskey dent in it, and after re installing it closes like it should. The drivers side door has some good rot that i dont really know how to fix and the real annoying part is, i cant seem to get it hung right... The front fenders are not the OE ones and i know chevy used horshoe shims for a reason.... and thought it was the fender interfering. After about 6 times putting the door on and off alone... i said screw it.
Ive had these OE 73-76 door shells in the se can, as i had sold them, but the guy backed out awhile back and theyve sat... i thought hell, it weighs nothing i should toss it on. I just bolted it on. Moved it a tad here and there and bingo... The fender gaps so much better and it hangs properly and all lines up.
Overall this door lines up with every body line better so now even if theres some sag and what not when its 30 lbs heavier... it should still be nicer, worst case is rust free and thats fine with me. This road does lead to some new tasks... and its already pouring sooo why not get at it while i can.
This door has a dent in it at the body line, which isnt too bad. im sure the high could be heated and hammered and the inverted section pulled out.
Sound proofing the doors with kilmat or whatever should probably be done but not sure if its the best option for weight. The weight of that stuff adds up.
I have some of the newer style mirros in factory white i presume, and the hardware but i have to make sense of my unlabelled ziplock now to figure out how the inner braces are installed.
Interior door panels for these trucks are damn pricey for repops... The hunt for some used ones begin, tossed a wanted ad in the parts thread if anyone knows of any. Dont care about color or what not.
doing this one means i should do the pass. side too...
