I really like your idea hear. The trans is meh though.
I did a mid 80s T5 transmission in my S10 V8 swap years ago. I had the bell housing and everything so the whole thing was angled like it was in a Camaro. So weird they did that. Anyway mine had a bent shift fork and wouldn't go into 5th gear real well. All of my forcing it wore out the synchro so I pulled it, fixed the shift fork, replaced the shift fork pads and the 5th gear synchro. 5th gear worked like a charm but it started popping out of 1st every time you took off hard. You could hold it in 1st and it was fine but super annoying. I ended up selling the truck like that so I don't know what happened exactly. But my mini rebuild showed me that these transmissions are pretty simple and easy enough to rebuild. Perfect for a 1st timer. Hardest part is lining everything back up to put it back together.... Nevermind those extra parts..... Lol
Cleaned up alot and got a yet another list made of things to tackle on the truck. Gonna have to sit down and amalgamate all of them into one solid list someday.. Got the drivers side door hung and gapped to where it looks good, and feels good. So much easier when the door is just a shell, Should i be compensating for any sag once the doors are fully assembled with glass and everything?
