Got the wiring all connected. Tested the grounds, and everything has less resistance than .025-.3 ohms between the main grounds. I think .05 is what i read should be the most? I did mess up and connect the usb plugs and gauge lights into a hot at all times run off in the fuse block. So that will need to be changed, and my blinkers are acting wierd also.
Both front side markers dont light up, most likely burnt bulbs... Tested for 12v at the brown wire leading into both sockets and have proper voltage there so the bulbs must be junk. When the blinker is turned to the left i have no blinker, just a solid rear tail light. So i thought okay maybe the flasher relay is junk too, but i have blinking happening on the right turn signal side of things. I even tested the side marker socket with the right, and left turn signals on, and the right side shows a pulsating voltage from the blue wire, and the left side just a constant 12v. Im confused about this because the right side stuff all branches off the main wiring which runs to the left side first, so for that side to be acting up makes me confuzled. Im sure ill figure it out, just need to scan over my wires, and the wiring diagram. Im just super stoked almost everything is fine on the electrical side, and nothing fugged up yet.
One thing i never really checked much, was if using the th350 dip stick will give me an accurate reading in the oil pan of the 4l60e. Pulled the dipstick yesterday and there seems to be way too much in there, but is that just what would normally be in the transmission cooler lines and cooler since you check with it running? I have to drop the pan to weld in the bung for the temp sensor anyway, figured id measure what comes out vs the recommended fill volume, and compare.
