I think so. One tire is brand newBaker's old wheel/tire setup.
Yes it is. He didn't want it sitting there anymoreIs that Justin's rig?
Martin
Wonton is also from justinIs that Justin's rig?
Martin
He has a c30 dually but I think he's keeping it. Other than that just the camo truck which I think he would sellI know.
Does he have anything left?
Martin
Sweet. If you can do it... Jk Steve. LolI second that notion.. Ive read the stuff over at pirate and swapped my sector over..
It wasn't too bad. Getting all the balls back into it was a little trick but once I figured that out it was easy.How did the steering box rebuild go? Be been thinking about rebuilding mine rather than paying for one that some other monkey like me rebuilt.
Was it just hard to keep them in place?It wasn't too bad. Getting all the balls back into it was a little trick but once I figured that out it was easy.
Yeah its hard to expain. You have to basically make a circle with them inside of the the piston and then thread the worm gear in. Wheel bearing grease helps to hold them in place and then I cleaned it out with brake clean after it was assembled.Was it just hard to keep them in place?
I think I know what you are talking about. Vaseline works good for holding things in place. I worked with a guy that used it for building transmissions and transfer cases and he never had any issues with it. I've been partially into a steering box but haven't tried to rebuild one so this is good to know! Thanks!Yeah its hard to expain. You have to basically make a circle with them inside of the the piston and then thread the worm gear in. Wheel bearing grease helps to hold them in place and then I cleaned it out with brake clean after it was assembled.
