Heres a picture of my drag link, made it out of a dana 44 tie rod, there is a solid shaft inside of it where i spliced it, should hold.
This was also my second attempt, the first one i made the bend to close to the oil pan and i tried to fix it, it got worse, and then worse.
Also found a bunch of cylinders off a concrete saw, might see how much movement they have and try and build a hydro assist.
