suspension all in minus front shocks (need some ford towers). brakes bleeds done, fuel tank is in with all new flex lines. fluids changed in engine. got stuck with the steering gear though. since my 2wd one is outta my 78, apparently the fittings on the ends of the press line are different then in 83 so i have to either make a hybrid press line with different type ends or go buy a 2wd box for the correct year. otherwise its ready to test
