So when's the big cab swap attempt?
Probably tomorrow.
short list for tonight
1) Install MSD adj. rotor and phase it correctly
2) add trans fluid
3) run a brake line down the frame rail and secure it (easier before the cab goes on)
4) wrap the exhaust and tie it off
5) install heater hose barbs and loop the heater hose
6) add coolant
7) add some gas and put a temporary fuel neck on the tank
8) Install cables @ Trans and T-cases
once the cab is on I can install the battery box, wire the starter, alternator, add grounds and wire up the power to FiTech.
Do some basic programming on the FiTech handheld
I think I can fire the engine at that point.
Probably tomorrow.
2) add trans fluid
6) add coolant
That's a decent list for one night, but getting really close to firing that bad boy up. Can't wait!
Did you buy a new harness for the truck has a whole or just reusing what was in there?
using the stock harness which is pretty damn simple being a diesel cab. Most of the harness is lights then you have a couple sensors, coil and fans. The taillight harness was a little hacked up, I may need to solder in some new sections on that.
There is no reason to solder taillight wiring.
Yes. A good set of crimpers, non insulated butt connectors and heat shrink.
It is a light. Not an injector, or sensor or ecu, etc.
The tiny, tiny bit of extra resistance won't change a thing.
I prefer to solder over crimp, just a personal preference.
So you're that guy! Do you also love scotch locks? Lol
Scotch locks drive me nuts too.
One of those thugs is what caused me to think my trans was going out in my SAS truck. It was causing a short in the wire for my trailer breaks and preventing the TC from locking up. Also caused my break switch to burn up super fast.
I lost a whole night of snowplowing, 6-8 hours lost at 72$ an hour. Over a scotch lock a "professional" used.
Wiring shorted. My plow stopped going up. Agghhh!
By the time I chased it down and replaced the storm was over.
@mrk5 that MSD adjustable rotor is to be used on distributors you modify to be locked out. It does not fit on the 85501 distributor and is not needed. Just a heads up....
