ekajkrats
Making good progress. Keep it up man! Having faulty new parts doesn't help. Glad you got that figured.
Working through some issues, first was a fuel pump that wasn't priming. Was getting low voltage readings, double checked the grounds and added another from the tank to the frame. Got 12 volts at the pump but it wasn't running. Pulled that out and jumpered it directly to the battery, still nothing. Decided to stick a probe in the pump and see if it would spin, it was a little tight and then spun like normal. Now it's working.....thanks AC Delco.
Now I'm trying to figure out why I don't have spark.
I think I'll reach out to the FiTech FB group and see if they have any ideas
Its been a while since you posted this, but what do you have going on?I think I'll reach out to the FiTech FB group and see if they have any ideas
Can you hear the pump prime when you turn it to on?
Did you change the handheld settings from 2 wire to tach (your running HEI right?)?
Do you get rpms when cranking?
Hopefully these questions are useless and you got it running!
Suck part is none of us have a clue to help you
I ready to rip out all the hack wiring in this thing. The more tape I remove the more shit I find.
