B
Bent77
Guest
Innovative
Is the bearing plate cover a ruffstuff item?
Several holes didn't line up anyway.
Gonna layout with the gasket...
That would be the right way.
I'll need to remove a piece of that plate to accommodate the JB shifter plate which also bolts to that cover. In hindsight I probably should have used a TMR kit or made something.
Tomorrow AM I'll remove the front main crossmember and add a bunch of tube I cut today that will extend to the front of the trans pan.
Pretty sure it's not a symmetrical bolt pattern, i.e.you have to keep turning it until you get the right pattern! I thought there was an issue too until i figured that out.
That flange implementation is simpler than I had in mind and makes a lot of sense. Good job!
Can't you just weld or drill/tap/bolt the shifter plate to the existing plate?
Might be a silly question, but did you flip it over and try clocking again? It has to be the right side out too.
Sorry you had trouble with the parts. I'll look into. Wished you would have said something.
So what is the clocking in either degrees or inches to get it that flat?
More dumb questions:
Can you get the tranny pan off?
Is the rear cross member hanging that much lower than the t case, or is that an optical conclusion?
Polish horses play frisbee?
