Sawdust is almost as bad as grinding dust, that shit gets everywhere
yep.
One day I'll have a shop broken into three or four different sections with a dust collection system.
Tell me about it. I don't go around insulting anyone else's occupation without provocation.
Now residential electricians are a different animal. They are typically the bottom of the barrel.
Same post.
Martin
Big project, you going to "build" the frame first (boxing, blast, paint, etc,) before or just swap-a-roo??
Smart to do this now rather than after you've done even more work to the old one.
Yep.
Need to strip all the unneeded brackets and crap off it first.
I figure the only real work I'm losing is the sliders. Sure I spent some time removing rivets and installing the flip, A-Bomb, rear shock crossmember, fuel tank etc. but that stuff all unbolts and swaps over.
Rear driveshaft will need to be shortened, the front purchased because I'm adding the eco box/th400 so it's a good time to also reevaluate the wheelbase.
I don't want to get too stupid here as I plan to wheel this truck all summer but I want to be smart about it as well.
The plasma works awesome on those stupid rivets. Fastest thing I've used yet.
I was thinking about trying that....
If you had to box the frame again would you buy DIY's kit or pick up a sheet and cut your own with a plasma? I'm leaning toward just doing it myself.
Try it. It's awesome if you just make circular patterns on the rivet head, it goes away and anything left is slag.
I'm 50 50 on the frame kit. It's convenient but then not. Every frame is a bit different so it's hard for them to nail it perfectly. You're starting with basic shapes but it's not split around the areas like the motor mounts.
I say do your own. It's gonna take a little longer but you'll be closer to what you need. Can't beat the cardboard cut outs.
I'll give it a shot
That was more or less what I was thinking and planned to do. I know I can save some money and I'll end up spending more time however I have all the right tools to do the job.
I know the frame contours are a bitch...
Valve covers look good!
So does that drive train set up![]()
Wish I would of known I have a mod Harbor Freight blasting cabinet that works awesome and someone with knowledge to get all parts needed anytime.
That drivetrain is awesome looking. Should be beef!
