B
Bent77
Guest
Suck about the intake
What damper did you get?
That might not work for you. Says not to spin it past 6
I bet 9k would be fine tooIt says at extended use past 6000. That means he can go up to 8 grand every once in a while.
hopefully they get here tomorrow so I can assemble the engine.
To go with your half set of head bolts?
its that simple.. i actually used to pull the switch by hand if i didnt get the kickdown when I wanted it..(long arms)
It might be nice to have an extra that you can push when you want.. almost like a grade gear switch without having to shift into 2nd??
