Knocked a few things off the list today.
- installed 4 degree rear shins and adjusted the anti-wrap.
- installed windshield
- cleaned up dash wiring, mounted the trans temp gauge and the CB.
- installed the rear view mirror & roll bar padding
- installed the tube doors
Dropped the kiddo off at school, scared a half dozen soccer moms in the process. On the way to work I noticed a little bit of an issue with what feels like steering box slop but then when I make a small correction it feels like it's over steering so I'm quickly trying to counter that. I'm basically playing pinball down a single lane. After work I'm going to look it over closer and double check the alignment.
I had a similar problem tracking down the road, and found the pitman arm nut was starting to loosen.
David
David
that's scary, I'll double check that.
I know the box is tight to the frame, I checked that the other day.
