In my opinion, the pushrod is the easiest part if its adjustable "all thread" like AA gives you. Make sure the parts that are inaccessible when the engine is in are right first cause it's no fun to remove the motor to fix it.
If you can assemble the fork, release bearing, and bellhousing, mark the maximum and minimum fork positions with a sharpie somewhere that's easy to see. Don't use any springs for this. Then bolt the motor on with the clutch pressure plate and see where the fork position ends up between the marks you made.
If the fork is too close to the maximum fork position, you won't be able to release the clutch.
If the fork position is touching the minimum position mark you made, you'll burn the bearing up and be slipping your clutch.
Ideally, you want the assembled fork position close to the minimum position without actually touching it. That ensures all the fork movement when you press the pedal is going towards releasing the clutch and not just moving the bearing closer to the pressure plate.
