'84 K5 Build (Midlife Crisis)
That 4" hole saw is putting work! Looking bitching as usual brother.
Clever welding platform! I like how the main hoop is so perfectly parallel to the b-pillar.
David
Once it’s over 100 I just get angry working in that $hit. Tube work looks good.
Thank you, man I know exactly what you mean. I had planned to get up early and try to get those two upper front to rear bars welded in, but my body said nope! :dunno:
So, I’ve been battling an issue with the rig the last couple weeks. Every time I would go to start it after sitting over night it would act flooded. I would have to open the throttle wide to get it to fire and clear out. Once it cleared out it was fine. Drove completely normal. Kept cutting back on my cold cranking pulsewidth and it kind of helped but not much. Thought maybe my Megasquirt was having an episode. Well, the other day I could smell fuel just sitting there so I popped the hood and could tell it was running out the air filter. I think I found the culprit....
I wonder if that had something to do with the issue we had on the last trip?
