Fuel pressure regulator diaphragmWhat is that part?
I will agree that this heat is not helping. You are not the only one bringing up weird issues. About two weeks ago, my 2017 ram work truck cranked and cranked for about 10-15 seconds before it started. I was like wth? My neighbors Jeep has been doing all kids of crazy stuff too. Was not wanting to start right away and died while idling when he took the gas cap off. My blazer did that too a couple weeks ago...I believe it could be the hot weather. Ever since it got hot both my computer controlled cars are having the same problem starting during the heat of the day when the engine is cold. I think it could be that when the weather is 115 degrees the O2 sensor is also at 115 degrees, which is the same temperature an O2 sensor starts to lean out the engine, but the engine tries to start in rich/cold mode. This causes the vehicle to go loopy, and run like crap for a minute until the vehicle goes into lean mode. Or I could be I am full of sh!t, and I do not know what I am talking about.
Apply some resin and fiber mesh and it will LOOK fine
If I was Mike Patey, I’d make it out of carbon fiber haha.Apply some resin and fiber mesh and it will LOOK fine
Thanks!Looking good brother!
Now the key is really stuck haha. Went and bought a new one and it’s good to go. Noticed my horn contact tower was broken so I ordered one of those. Better now than Moab...Boxing that section between the link mounts? I’ve seen a couple skids that wrap around and bolt from the side.
The link mounts will get tied together one way or another eventually, but the skid is just going to bolt on to the front and rear x-members.Boxing that section between the link mounts? I’ve seen a couple skids that wrap around and bolt from the side.
For sure! I only have to do it about twice a year.Good thing you live in a dry climate! That thing would be crazy rusty otherwise. Lol
When I built my truck in 2015 I never painted the tierod. I was going to replace it with a aluminum one but never did... it's still on itGood thing you live in a dry climate! That thing would be crazy rusty otherwise. Lol
It’s a dry heat right? HahaWhen I built my truck in 2015 I never painted the tierod. I was going to replace it with a aluminum one but never did... it's still on it
