Maybe because mine is a 383? Idk, mine sure falls flat. Maybe I’ll look into a bigger throttle body.Meh, factory LT1 will turn 5800 easy. With a 750 throttle body and some warm ups, they go 6500
I was just going to add that, and I think that’s valid.Maybe because mine is a 383? Idk, mine sure falls flat. Maybe I’ll look into a bigger throttle body.
I do know the stock block LT1 with just exhaust, tune, and TB/cold air will make 460 lb/ft at the flywheel. That’s impressive for any NA small block
So if you have a good l31 long block and a TPI setup and you are building an overlander, would you use the TPI or the vortec stock setup?I'd have gone this route if I could have found TPI parts cheap
I think its the best factory injection setup, and can go without a VSS in the transmission
@TJ1978
The MPFI isn't bad, and if you already had it with vortec heads, I'd run itSo if you have a good l31 long block and a TPI setup and you are building an overlander, would you use the TPI or the vortec stock setup?
Does the TPI even fit on the vortec heads?
I could never run a vortec setup. Every time I think about that bolt pattern I get a twitch in my eye.
I always thought that and I have the complete setup so my plan is to put it in my 89 suburban.I'm a huge fan of the L29/L31 platform. Cheap and easy power for old school SBC/BBC, at this point though it's getting to be just about as cheap to swap in a junkyard LS and call it a day.
I wonder how similar the new ProFlow is to TPI. https://www.summitracing.com/parts/edl-357900/make/chevroletI'd have gone this route if I could have found TPI parts cheap
@TJ1978
I almost bought itI wonder how similar the new ProFlow is to TPI. https://www.summitracing.com/parts/edl-357900/make/chevrolet
Looks more like a ram (stealth, jet, mini, etc) intake to meI wonder how similar the new ProFlow is to TPI. https://www.summitracing.com/parts/edl-357900/make/chevrolet
I was thinking operationally more than visually.Looks more like a ram (stealth, jet, mini, etc) intake to me![]()
I did a bunch of research before buying a crate engine. I couldn’t find a 6.0 with the comp, wiring, and accessories for less than $2500. And it was still usedI'm a huge fan of the L29/L31 platform. Cheap and easy power for old school SBC/BBC, at this point though it's getting to be just about as cheap to swap in a junkyard LS and call it a day.
I was contemplating that one
By looking at them and knowing what harbor freight has been doing I would say it's the same Chinese manufacturer.Saw those in Harbor Freight, but I was surprised at the price. I'd rather have a Warn for the same price. Although that Warn has steel cable, but I already have the synthetic line. I also don't know much about Badlands so maybe it's not that much different from a Warn.
As far as I know yes
