87 Blazer The Turd build
IMG_0708.JPGthe skid plate came with the doubler also if you look close at the 2nd cross member you can see were the bolts line up with the plate .i cut 3" off the front to get it to fit and im drilling some holes in the for the 1st cross member but its where it will be until i change it .i think all 3 crossmembers will be sturdy enough
Sorry to nitpick, but you shoul hit "RETURN" after you post a picture and before you start typing text. It makes it goofy to look at otherwise.
Martin
i was going to do some updates ,i have a bunch of pics ,but its telling to contact admin and has missing security token!:dunno:
That error just means that the total size of your 5 pics are monster large and over the total size limit. Either size them down a bit or upload one at a time.
Sorry to nitpick, but you shoul hit "ENTER" after you post a picture and before you start typing text. It makes it goofy to look at otherwise.
Martin
fixed it for ya... ;) just hit it a bunch of times to break the posts up a bit...
working on the front end
IMG_0770.JPGB 52 installed
IMG_0767.JPGfinally a kingpin dana 60 :woot::woot:
IMG_0835.JPGafter the clean up and paint
IMG_0946.JPGcross over steering painted
IMG_0930.JPGORDs cross over steering kit ,pics out of order :doah:
check it out turd out of the garage
IMG_0888.JPGso close about 2"too tall
IMG_0891.JPGanother view
IMG_0933.JPGtire psi 5 to get it out
IMG_0949.JPGthe beauty shot
IMG_0943.JPGcleaned up the garage and put it back in
i still have a huge TO DO LIST!!!!
take a look at the rear shackle angle ! :eek1: way wrong
those hangers are coming out.
i picked up a set of ORD 2.5" hangers should correct the angle .
once i get all of the steering and hydraulic assist finished i will post more picks
l
What flip brackets are you using right now? With the ORD flip brackets and 56" rear springs, make sure to install the brackets flipped to how the instructions tell you to install them. They say to install with the bracket angled to the front of the truck. Flip side to side and intall with them angled to the rear. Then the shackle angle should be about perfect.
Looking good dude. When we gonna wheel?
The brackets are from gatsby truck , i knew about the ORD side to side for 56 springs . I still have a way to go but front locker and gears first part of July . Then for the shake down run
power washed ,wire wheeled ,wiped it down with paint thinner and painted
small update we are back from our vacation in washington state went to see my son alex graduate from high school .
IMG_1077.JPGhydraulic steer assist is in
IMG_1078.JPGmoved the factory mount over about 2"
IMG_1080.JPGfill tube and bracket installed
IMG_1082.JPG just a peak at the cage more pics when done
making progress
the winch is installed and wired up ,i relocated the solenoid box for clearance reasons. i didn't. want to use a body lift. the little box next to the solenoid is for wireless remote.i stiil really like the TNA winch cradle :thumb::thumb:
it a great fit ,should have a good approach angle.
IMG_1165.JPGrandom pics of the cage installed
IMG_1168.JPGthis sticker was meant to be on THE TURD:whistle:
IMG_1170.JPGfirst cut of many :haha:for the tripple sticks
IMG_1174.JPGholes gettin bigger:whistle:
looks like the grand canyon :eek1:but thats what it took to get the shifters moving smoothly ,it also makes for easy access:thumb:
IMG_1180.JPGmock up for the cover
i had a stack of old plates laying around ,so decided to recycle them .i recycle beer cans too:rolleyes:
i also bled out the brake system, snapped off the bleeder on the left front caliper tried to easy out that ,found out that the fuild passage was blocked with rust !so i replaced both the calipers and new pads .no pics bleeding brakes isnt that interesting.
heres the ORD 2 1/2 shackles installed ,has a better shackle angle now.
changing the shackles out didnt change the ride hieght 1/8 inch taller now ,thats with out the fuel cell in it
i picked up a set of hooker headers and magna flow mufflers .i started the removal process and broke every bolt off in the manifolds:bow:
picked up the cooper gaskets for heads and the collectors,i ordered the O2 sensor bungs,and i have to go ace hardware to see what i can come up with for the air injectors.:dunno:if someone has a solution or suggestions for this :ears: I'm listening .
Damn! I hate broken bolts.
What do you mean "air injectors"? Air/smog pump related?
Mr. Hankey looks mean btw
