Found 87 STEERING COLUMN - Tilt, Automatic
TeamVoorhees
Florida
Need the entire steering column if its in vy good shape (do NOT need or want the steering wheel). No worn or wobbly bearings top or bottom. My entire column needs rebuild but I can't find all the parts to do it. I'm in Florida panhandle. Thx.
I have a 30k mile cucv pullout. Ugly but a nice column. If you can make it look nice then this is for you.
I'm going to try replacing the bottom bearing where the steering shaft is wobbling and flopping around... if that doesn't fix it, I'll be back looking for a whole column. Thanks.
If you change your mind let me know. I have a tilt column from an '89 Blazer.
