chevysmithz71
I do plan on leaving them. I figure if the pros at ORD make them this way, I should be good..
roger that. i think i was picture the diy setup, but even that is only a single plate coming off i believe, just has a wider outside piece.I do plan on leaving them. I figure if the pros at ORD make them this way, I should be good..
carry on![]()
right. i have one as well. its a single flat coming off the frame which is where the logo is cut in, and than a wide flat piece "boxing' it on the outsideNope I have diy4x's and it's essentially a boxed piece. Not just a single plate with gussets.
Just curious, but if you have a set of ORD shackle flip brackets that you copied, why not just use them? Or did you borrow those?
Martin
they sell 1 ton brackets. I have them.
Ive built every flip I've used and pretty happy so farThe space between spring and frame is 2" on all 1/2 and 3/4ton and the ORD brackets. 1tons are only 1.25, well My dually is, not sure on others.
So the angle of the bracket off the frame is different. Ill get a side by side shot to really show the angle difference
its a few frame dimensions that are differnt
Ditch the sway bar, you won't miss it.
Martin
