bronc3buster842001
Ya... Where the hell you been hiding... Was gona stop by a few times that i was down that way... Just never know when your home.
. My brothers isnt finished cuz hes slow, and my buddy blew his 03 8.1L up so his 79 is on the back burner. Mine is just a driveshaft away, and I can see past that thing for the right type of time.I'm usually home long enough to sleep. I'd say on the weekends if the black crewcab dually is outside i'm home. It's the only thing running now.Ya... Where the hell you been hiding... Was gona stop by a few times that i was down that way... Just never know when your home.![]()
Just curious since yalls is "Misery" located folks, do/are you going to Buchanan's Mudfest May 4th?
Not sure why he decided to put the shackles up front but it's coming together pretty quick actually.
I always wonder why this isn't done more often. I read one time that shackles in front help push that axle over an obstacle when it flexes. I've been waiting years to see it done on here to verify the accuracy of this statement.
Never been but I have a couple friends that take their cummins powered huge Chevys up there. Almost flopped the one over on its side. I wanna go once but think its alcohol free. Nothing wrong with that but I like to drink and watch people tear up there trucksJust curious since yalls is "Misery" located folks, do/are you going to Buchanan's Mudfest May 4th?
My input was basically the same. REad about it years ago. I know jeeps are set up this way but figured there was a reason Chevy did it different and kept it that way for years.I researched this when I built my SAS S10. Front shackles adds a bit of complexity as it almost requires a track bar to prevent a sloppy feel in the steering. The front shackles will allow more side to side movement of the axle during steering input.
Front shackles also cause a harsher ride feel vs rear shackles. When going over a bump the axle moves up and forward kinda pushing the tire into the bump. Rear shackles allow the tire to move up and back effectively soaking up the bump instead of pushing into it.
In going over an obstacle like a rock or stump front shackle design fights the vehicle weight and can bump it backwards making it harder to get over. Rear shackle lets the suspension do it's job moving the tire up/back while the vehicle moves forward. Now once the suspension has had time to react the vehicle is already on top of the obstacle. This all happens in fractions of a second. I ended up building mine with front hanger/rear shackle and it worked awesome off road, rode great on road, didn't need a front track bar or even a sway bar and pretty much handled like it was made that way from the factory.
