I always wire the stereo so it can't be left on with the key off.
@doubletrouble said I need to drive it more too. HahaThat is when battery cut offs come in handy. Anything can be left on, if the entire system is shut off.
Or, DRIVE IT MORE OFTEN.
I defeated that with my airplane cockpit setup. I can't leave well enough alone.I always wire the stereo so it can't be left on with the key off.
I also said that it sounds like you’re not responsible enough to have a stereo.@doubletrouble said I need to drive it more too. Haha
I do have a cutoff, but ironically I don't use it because I hate losing my stereo presets.......
I've been running mine backwards this entire time!
At the time this happened I was pulling the 7000lb Savalanche thru deep snow. I had the throttle nearly pinned running 2nd gear, both lockers engaged, and in double low. I'm thinking one of the times the Savalanche got stuck the crew cab hit the end of the rope bringing the frame to a complete stop but the axles kept pulling forward. And due to the deep snow, there was a good chance the suspension was drooped out on that side.The only other time I've seen that is on the driver's side with factory steering and that's been a couple times with different spring brands/types. In that situation, the truck was in reverse with the left front drooped out and trying to steer left. The force of the truck pulling backward plus the steering force pulling forward plus the leaf being drooped let the truck basically over run the axle a little bit and it bent the main leaf. When you think about the main eye pushing on the leaf, things go pretty well when the leaf is mostly flat but when there's a lot of droop involved the leaf isn't in a very good position to transfer force from that main eye to the axle. And the shackle end is pretty well just along for the ride since it has pivot points on it so it can't help.
If you ask me staying off the skinny pedal is not a correct option....The only correct 2 options are....
Stay off of the skinny pedal.....
Links on everything.....
But....While it is true that links are awesome, they have their own problems. Instead of throwing in a few leaves which you can grab from a junkyard, your replacing heims, which you can't get from a junkyard. It all can break with skinny or wear.
But....
You can never bend a floppy spring if you have links.
