Sounds like deja vu, someone recently did the same on an 8.1 in the master thread, same thing many said to eliminate it.I need some help with the engine oil cooler fittings. Most of the info I've found is about eliminating the cooler, but I want to run a cooler.
I've read suggestions to replace the 2 factory 11psi bypass valves with 30psi units. Would this send more oil thru filter? I'm having difficulty visualizing the effect of a higher pressure bypass.
I want to replace the factory lines with -6an (maybe -8 given the size of the factory lines) so I can plumb a cooler where I want. It seems the fitting closest to the filter needs to have a do-dad of some sort or the oil will just bypass the cooler. Scoggin Dickey used to make an adapter with the do-dad, but doesn't seem to be available any longer.
I could cut the factory hard lines and use a compression to -an adapter assuming it's a size I can get. Can I get some sort of replacement seal for the factory lines? I broke the plastic collars that go around the clip.
Any one have more useful info?
Some associated images:
The fittings in question:
Info on what port goes where:
The Scoggin Dickey adapted:
I say keep it and check it out the 8.1 might be very similar
