I would do a burb tank 44 gal.
Although mine does fine with a Blazer tank.
From a 90, so it should be baffled, and the pump, sender and factory skid are all thereOther downside is the 40gal tank costs $50 more; $90ish compared to $140ish. Although @Justin V told me he has a 40 laying around.
None of you guys own a degree wheel?
Whoa! Sounding better by the minute. We must talk when the bank is recouped from Christmas.From a 90, so it should be baffled, and the pump, sender and factory skid are all there
I've caught 2 bad timing sets that way. I don't install cams without one.It seems like the only thing that degree-ing a cam is to verify that the cam is what the specs say it is. If a cam happens to be 1 or 2 degrees off on a lobe (which many are and most people do not know it) then what are you going to do. Most people just run it anyway.
