did you ever see if the steering is limited by the steering stops on knuckle before the box is turned max? If so then find a shorter pitman arm.
One of my pre-trail checks is steering box bolt torque, at least for serious trails or trips like Blazer Bash. I have a theory that's how many cracked frames start.I have plated the back of the frame with something thicker and then just drilled the stock holes through it.
Problem with that is if it ever gets loose then it can easily wallow out the hole. Not really likely but it could happen.
I had so many issues with the steering box I wanted to literally never even think about it ever ever again.
And I didn't
Yes I did. Your comment rang in my head at one point as I was getting everything buttoned up. I am not limited by the steering box. I have been doing some searching for pitman arm choices but I was looking for shorter drop as opposed to shorter length.did you ever see if the steering is limited by the steering stops on knuckle before the box is turned max? If so then find a shorter pitman arm.
Trevor at WFO sold me a yj, xy, something jeep and reamed it out for 1ton tie rod. It shortens it just a bit and has way less drop. Maybe give him a call?
Thanks. I was just thinking the other day I need to make sure and preserve the 3+3 badge.Great looking truck! I always loved the 3+3's
I'm glad I'm not the only one that has had to do the same. I do think there may have been some goofiness with the suspension with the springs angled like that.I did something similar with the front spring hanger on the old sonoma, and lowered it down a few inches. Lost some approach angle but the axle travelled more vertically and not up/back into cab and was able to ditch castor shims too.
Thanks. It feels good to have the issue resolved.Way to make lemonade!
