With winter upon us, it was time to address some comfort issues.
Replaced the window seals on the rear doors. The channel seal that runs up the back channel was complete gone on both rear doors. Driving on cold days meant getting a blast of cold air on the back of your head.
Got a full set from 1A Auto that included the run channel and window sweeps for inside and out. The run channel seal was one that runs up both the front and rear channels and across the top all in 1 piece. Wasn't much to the install. 1A Auto has a couple of videos showing how to do to the install on front doors but it still helped with the rears.
Had to remove the door panels, but left the windows in. There was a bolt I removed that holds the rear channel.
That gave me enough room to be able to slip the channel run seals out and back in.
The other thing to watch for is a snap in plastic piece in the top of the run channel. Gotta make sure you remove the old one completely so the new one will go in. This is a picture of the piece left behind after pulling out the old seal.
The window sweeps pop out and back in like the video on 1A Auto shows.
Here's the outside of the window all sealed up, FWIW.
The other thing needing attention was the heater control. The only things available were hot and defrost. The levers all moved freely. I had to pull the controls out to see what was going on.
What I found was that the cable for the heater/defrost selector was bent up so that it wouldn't move anything.
And the cable for the hot/cold selector wasn't anchored.
Luckily I was able to use the cables in the General to replace these. Hat the replace the blue because it was bent up and the red one had to be replaced because it wouldn't stay in place anymore. Here's where the red cable should be anchored.
I swapped the entire control unit in from the General. The down side was that the chrome tip had been broken off the fan control. It was easy to just swap that over from the other controller. The chrome tip just pulls off, remove 1 screw from the back side, and pull the switch out. Here's the screw:
The other wonderful thing I discovered was more wonderful wiring by a previous owner. Apparently they had cut the heater fan control wiring at some point. And also had to splice in a length of green wire into the power supply wire.
They had also cut one of the wires on the light for the heater controls. There are 3 other cut wires that I'm not sure what they are for. They are small gauge wires, 22ga probably, so I'm thinking they may have been for other lights. The only dash lights I have is half illuminate the speedo and fuel level and now the heater controls. Another wire that was spliced in at one point and now it's cut.
Who knows what the hell that was for.
With all the wiring BS I keep finding it gives me piece of mind to know I have my fire extinguisher stashed in easy reach.
