Nice!
Does that mean the LS swap is off?
I don't know that it could make that much of a come back! Hopefully it only means the drive to Moab just got a little less difficult.Nice!
LOL! I hear ya. That's pretty much how I felt about minor improvements to my old motor.I don't know that it could make that much of a come back!
I had some AC Delco rapidfire plugs to put in but for some reason 3 of them had different electrodes even though the part numbers were all the same. I bought them 3yrs ago so unfortunately I didn't have any exchange/refund opportunity. So I ended up with some NGK spark plugs. The cap and rotor are AC Delco tho.Wow, that's good for you and your truck! What spark plugs are you using. I returned to the stock AC Delco plugs on my Mr. Goodwrench 350 and it made a big difference in the way the motor was running when I switched from a carburetor to TBI.
Is this all at idle? I set mine at 38 degrees btdc at 3k rpms with vac advance hooked up on carbed engine. Its at like 30 btdc at idle with vac advance plugged back in and runs awesome.
Hmmm, no. I may regret it, but I haven't. I just have the bolt-on brace. I guess I'm hoping the bolt-on brace and hydro-assist will hold off any problems.Scott, have you done a weld on brace yet? Curious to see what is needed to be done.
Only a 2wd frame guy will know what I'm talking about.![]()
burnoutHmm I think maybe I should check out the timing on mine.
Yeah, pretty much what Dremu said. The idle is set without the computer input by unplugging the wire. The computer takes over timing once engine is running >400 RPM. The timing I'm setting with the wire unplugged is the base timing. The computer doesn't really know what I have the base timing set to, it just adds the timing to it as it's programmed to.Is this all at idle? I set mine at 38 degrees btdc at 3k rpms with vac advance hooked up on carbed engine. Its at like 30 btdc at idle with vac advance plugged back in and runs awesome.
