Do they make u joint straps that would make that tab irrelevant?
I moved the carrier bearing back towards the rear axle about 12" to get a steeper angle on the driveshaft to attempt to keep it out of harms way.I may be late to the game to be asking this question, but...your carrier bearing is on top of your cross member and not hanging down below it like most carrier bearings. Is there a reason for that? The cross member does not look stock.
Never noticed that but I see what you're talking about now that you point it out.I see some casting flash in those oil drain back valley's. That means no one has ever de-burred that block.
We thought it seemed to be a bit more slop than it should so I put a new one in. Seemed like a no-brainer when they are so cheap. Did that yesterday. Spent quite a bit of time double checking the alignment marks.
