Are you going to give those a try?
I actually went with a Flowmaster but it's freaking huge. It is quieter than my old Magnaflow with the 350. I guess that's the trade off tho, the Magnaflow is more compact.Me either, I stopped buying flowmasters years ago. FWIW the single 3" through a 21" magnaflow is manageable through the drivers rear bedside on my SWB. If you swung it over the passenger side and it being further back it would be even better for the driver. I should
also note that I don't have any drone, just a louder exhaust note WOT.
I'll check into that...Love it. You should put a magnum behind it.
David
You going to pull the cab off to drop the trans in?
Negative. And I'm not meeting you guys at Wade's to help me do it either!that's my move
That's cause it's also not one of their cheaper items either. I eyed it for quite some time but just didn't think I could justify the expense. Now that I have it, I realize it is worth the cost IMO.I have that same trans jack...used it to install my Titan/205 into my blazer...probably one of the most legit HF tools I've ever bought![]()
I was thinking you where trying to say bunghole...to drain the fluid out the @Bent77 hole..... errr I meant DIPSTICK hole.
