My truck is quiet and respectful. Quite the opposite of Roseanne Barr.
anti theft AND T-caseI can make the pattern plate removeable like a stereo face plate and lock it in the console.I say you leave the shift base blank, doubles as anti theft when all the levers are every-which-way and the dude doesn't know.
See... doubleranti theft AND T-case
A little but at least on the stand there's more slop in the cables than the bracket.Scott, aren't you concerned with slop not using a nut and bolt pulling it together? I'd be grinding that box so I could use a nut.
I'm thinking I could make a hybrid of the ORD style. Basically and L bracket. Then it should work fine with a 1" bolt.Like the ORD version.
What about doing some machine work to the JB shift rail collar? Make a countersunk hole for the nut to sit in and then weld the nut so you don’t have to hold it.
