Motor Mount Mishap
So this is where I got on the motor mounts. Both ORD and DIY4X's motor mounts are 3" inside from ear to ear. The Dirty Dingo brackets are 4" from ear to ear.
So unless somebody has a better answer, if I want to use a competition style aftermarket motor mount, my options seem to be ...
A. Get ORD or DIY4X to build a custom lower half that is 4" wide.
B. Get ORD or DIY4X to build a custom upper half that is like dirty dingos but only 3" from ear to ear to fit their lower halves.
C. Use some sort of spacers or washers to bridge the 1" gap between the ears. This is pretty slapdick and I am not sure how well it would work both short and long term.
Suggestions?
Before the trouble with the length I was leaning towards the ORD mounts over DIY4X (even though they were almost twice as much) bc they appeared like they would position the engine slightly higher (the bolt appears to be on the upper half of the mount vs DIY4X's which appears to be centered). The main reason being that one of the large reasons I am moving to these mounts is to accommodate the new xmember.
Question
Finally I have this sensor on both sides of my engine and it does not allow me to fully utilize the dirty dingo sliding mounts. Anybody know what sensor is it? Can it be rotated left or right to accommodate the motor mount if needed?
